I usually override the color of the active track to pink for visibility. However, DMD2 would often display one or more line segments near the current location in a different color and style similar to the trails on the map. It is difficult to distinguish it from other map features.
Observed in versions from July to September 2024 on T665 (2024).
WOW that is a lot of scaling!! Fix that:
Press the Map Layers button (the round button on the top with the 3 layered squares).
Click on “Scale & Visibility” and then reduce the Map Scale!!!
For the GPX track line adjustments:
Click the round button GPX, then on the dialog that opens click on “SETTINGS” (in the bottom) and then adjust the line in “Sizes & Opacity”
