That is along the lines yes. Maybe even simplified without subfolders. Just a main folder to store routes, waypoints for an event or a day. Like if I were doing a multi-day rally I could have “Day 1”, “Day 2”, etc.
I am long-holding on screen to set markers on map with my T865 on DMD2. Is there an easier program to use and do this? I tried the online DMD2 route builder on phone to put several waypoints in one file to share with others doing events but I wasn’t allowed export without a route. Route will be provided by organizers day prior to start an I just wanted, for this event, bubbles on map to bring it to attention clearly where I must stop to check-in.
I found setting markers in OnX, exporting, renaming each file “checkpoint 1, 2,… etc”, moving into GoogleDrive, opening in DMD2 was an easy method.
I see the screencapture you sent and that looks intriguing. What gpx editor would you recommend or how can I make just waypoints and name them, in bulk, then import them as a single file?
