16 March 2023 at 12:33 pm
#1407
I’ve tested every POI and I found that the ones that are slow are: restaurant, coffees pubs & bar = 45sec shop & market = 1.49min comparing to your video demonstration of the POIs, mine way to slow. xiaomi redmi note 10s dmd v.2.96
First thing I would say is do you have a valid location loc when you start searching? I think im changing the code because when you do not it does a full search (full country), and that is indeed probably too much. How many maps have you guys downloaded?
I’ve downloaded 4 maps but only one is loaded. What do you mean by a valid location, if you mean that the gps is on the right location then yes. When the POIs search is finish I can see that the stores are in the right distance from my point on the map.
