23 January 2023 at 10:12 am
#853
I pressed SAVE before setting maximum brightness in setting, now I can’t set to maximum. How can I clear what I saved in DMD2 so that I can resave the correct setting?
Just do the dialog thing again:
Go to Control Station, pull the left menu, select “Detect Maximum Brightness”
A dialog pops up, do not press any button
Pull the top Android Menu and set brightness to the maximum
Now pull the top Android Menu back up to see DMD2
In DMD2 now press SAVE in the dialog that should still be visible
That is it.
