16 January 2023 at 11:09 am
#840
The easiest way to do that is by setting DMD2 as the default launcher that is for sure, that was the way the whole system was planned.
Another way to do this (probably) is to first open DMD2 and then only open Locus from inside DMD2, this way if you press Back in the controller (press and hold the bottom button) it will go back to DMD2… I have not tested this and some apps suck at this because when you do “Back” they have a confirmation dialog that ruins the logic.
