I dont think there is analog to OBD, I do know there is analog to BT. Basically a device that captures analog voltage and sends it over BT, then the app developer can “read” those values. We are actually developing such device, it will feature X amount of inputs for reading sensors like (Fuel Level, Voltage, etc), plus On/Off switches. This will allow you to not only read sensors but also control hardware from your DMD2 app, like use the on/off switch to turn on and off lights, ignition, whatever… Top secret stuff for now
Hi
Long time been using the DMD, and from when ODB2 option was included, I’m wrecking my brain thinking if there is a way to connect the DMD to an old (carburetor) bike, at least to have on the DMD “dash”: Temps, RPMs, volts and others if possible!!!
This is great!!! Now I have some hopes! THANKS!
Javier…
