21 November 2023 at 11:08 am
#3383
Hello John, thanks for your email. For example, if I entered Ceuta as the POI, it took some time to find the city and also stated the distance. If I then went to “navigate to the point” and did not select an external app for it but DMD2, then the system calculated for a long time but without any result, or I had to cancel the process because no result was displayed after 15 minutes.
Destinations that are only 10 or 15 km away are found quickly, so if I enter a street name in my place of residence, for example, the system finds it and I can also navigate there via DMD2.
Another question. Can you also save the offline maps on the SD card? Can DMD2 then use it if it works?
thanks for your support, !
