#2968
It looks like maybe there are issues with how you decide if you’re in range of the gpx track and if you should show the distance remaining. I’m guessing that there’s a simple check to see if you in range of a point? I had the distance remaining box keep disappearing when on long straight sections and it would reappear when I got to the next corner. I also see a similar behaviour when using DMD to make a route. On long straights it would keep recalculating to the route thinking I’d gone to off route. This also effects the distance remaining, it’ll hold a value until you get to the next point then jump. Probably requires checking where you are on a track segment line rather than just the point?
This is fixed on more recent version. It should not happen anymore.
Please make sure you are running the latest Beta version.
Thank you
