12 July 2023 at 7:56 pm
#2580
Hi John
I was wondering if you could add a sign on the map that shows the speed limit of the road you are driving on?
Also, is it possible to base the fuel range calculation on the OBD PID value for the odometer? The PID should be A6 in hex. This would be more acurate when you drive through tens of kilometers of tunnels or if you drive a distance without DMD2 on.
BR Jesper
