1 July 2023 at 6:40 am
#2471
Beta 2.99928 released: – Clock Widget available in the Home bottom slot – New Time indicator in the GPS/OBD Sensors widget (available for home / roadbook / map) – Route Planner – greatly reduced the chance of using a cycleway in the calculations – Home Panels (Left and Right) now allow you to change position by tapping on the title – Home Panels (Left and Right) now allow you to change position in loop with the same control, when it reaches then last or first position it will loop – Roadbook – Totals and Partials decimal places now apply immediate – Map View: when you enable the topo map theme the Advanced Topo Options menu entry is correctly placed under the Map Type & Style menu entry
Good!!! It works perfect!!!
