Hello John
There IS an problematic item in the gpx section.
When You have gpx Files allready loaded into dmd2 You ca See them only when the File ist ready for Display. When You so Something before ITS readyly loaded dmd2 Crashes.
IT would bei better to see which Files are allready within dmd2 and give them a colour when they are ready to be displayed in screen. I think the whole gpx Handling with loading Files aktivating Poi Search and soon should be thought through again.Loading and selection for aktivating should be seperated Prozesses. Otherwise You wait for stuff You have in the System but so Not use at the very Moment. Again there should be the possibility to Cache searches for every gpx file, so the search has Not to be calculated again. Hope this helps. Funtionality IS great now the Performance has to be tweaked
