#2004
jesper
Hi John I bought a DMD2 licence for devices without Play Store, because I will possibly be moving to a device without Play Store in the future. I’m using the downloaded APK and not the Play Store version, but it was not possible to activate the license unless I deactivated Google Play Services. When I reactivated the Google Play Services again, the DMD2 the “Buy Plugin” box reappears and when I deactivate the Play Services, the box is gone again. I understand that directing users to buy the license outside the Play Store is probably against Googles terms, and compiling two different version (one for Play Store and one for the website) is also hassle. But is it possible to change the code, so DMD2 recognizes an activated license even though Play Services are activated? Also i noticed when I tested a HID keyboard with DMD2, it requires three button presses on the arrow key to switch between widgets on the right when the left widget is in focus and vice versa. Is there a reason for this? Couldn’t it be that when the left widget is in focus, as soon as you press KEYCODE_DPAD_UP or KEYCODE_DPAD_DOWN, it goes to the previous or the next widget page? And the same the other way around when the right widget is active. Best regards Jesper
Hi John
Going to buy the map plugin, and was wondering if I can safely buy the standalone license and be able to use it on both devices with and without Play Services in the future? Also, are you planing on adding OBD Speed to the widgets? 🙂
Best regards
Jesper
  • This reply was modified 1 week, 3 days ago by jesper. Reason: I wrote GPS speed but meant OBD speed
