7 May 2023 at 10:27 am
#1737
Thanks Johnkeel
1718 wrote:
.../...You can load additional POIs by going to GPX – SETTINGS – Additional POI, this will make DMD2 load the selected POIs categories along the track. Everything is calculated ALONG THE TRACK. And yes, a Waypoint must be inside the same GPX which DMD2 will target the active one once you are on top of any of its tracks.
Sorry, I don’t find the menu you are speaking about, Is this because of the version I have (2.77)?
