#1333
CRF300L Rally 2021 everything works except battery voltage (and the fuel indicator but this is probably not exposed over obd2). I’m using ELM327 V1.5 (Single Board PIC18F25K80). When using Torque on the same tablet it can normally read battery voltage and other sensor info. If someone can help me troubleshoot this it would be great.
There are two ways to read the Battery voltage, from ECU or from dongle, in the new DMD2 Beta in OBDView Settings there is an option called “Get Voltage from Dongle”.
Can you tell me which other sensors work in Torque that do not in DMD2?
