22 August 2023 at 11:33 am
#1280
“will check the widget change, does that mean you can setup the widget once but it crashes only when its set and you want to change it to something else?”
I have installed widgets with an earlier version of DMD2. I updated to beta 2.89 and “original” widgets worked well. If I try to install new widget on the home screen, the widget change options do not open, but DMD2 turns off. I reinstalled the whole beta app and after that I couldn’t install any widgets. DMD2 shuts down every time.
