19 February 2023 at 10:57 pm
#1261
Tried the 2.89 with the new option. Still same behavior. Only works when car gets certain bumps. Normal roads no map movement and if app “wakes up” huge jumps of the map. This happens not with other applications. Regards
This is solved for next update, we will no longer rely on accelerometer since some devices seems to not work correctly.
2.89 still shows no lightning to indicate charging. S22+ Android 13
Can you share a screenshot of the screen? Just tested on S22 Ultra Android 13, charging indicator is there in the top bar as always was.
