If you record a track and safe it as a GPX file, this will work. If I want to open the saved GPX file (on the same DMD2 device) it gives an error that it is not possible to load the file and DMD will not try to load it again.
mentioned this in all DMD versions I tested till now 3.000018 and previous
3.00036 -> tested today and it seems to be working now as expected
