28 December 2023 at 5:06 pm
#3709
DMD 3.00019 released:
– Added Checks for map NEVER to try to be animated post invalid zoom levels
– Finally added code to check and report on GPX files that could not be loaded (no more stuck loading and probably no more load crashes) -> also shows error dialog to report to user
– Same as GPX Load check but for badly / problematic calculated routes
– Map Resume Position is now only done once map animator is ready
– Fixed cases where GPX Progress and Navigation progress could not be correctly resumed
– Fixed a case where deleting a GPX could hang the app
– Fixed a case where Tilt value was not being saved/restored
– Other fixes and improvements
