![](https://www.drivemodedashboard.com/wp-content/uploads/2023/12/navnerd_avatar_1-80x80.jpg)
Hi John,
Unfortunately, it seems the fix doesn’t work. Just installed version 3.00009. With it, I got the following automatically generated name:
70_00_01-01_00_00
(Device again the SAMSUNG Galaxy Note 20 Ultra 5G, Android 13, One UI 5.1)
If you have to touch the code therefore again, could you change the automatically generated name into the following format:
YYYYMMDD-hhmmss
This is the same format that many (if not most) digital camera apps name image files and has the following advantages:
a) Shorter (2 digits less, and especially no long underscores, so less space needed on the screen),
b) Starting with YYYY makes it safer against confusion due to different date abbreviation conventions in different regions of the world (e.g. YYMMDD or DDMMYY :-()
Thanks a lot!
