<TaskerData sr=”” dvi=”1″ tv=”6.1.28″>
<Profile sr=”prof6″ ve=”2″>
<cdate>1682927057766</cdate>
<edate>1683378483098</edate>
<flags>2</flags>
<id>6</id>
<mid0>3</mid0>
<mid1>4</mid1>
<nme>MotorcycleMode</nme>
<State sr=”con0″ ve=”2″>
165
<ConditionList sr=”if”>
<Condition sr=”c0″ ve=”3″>
<lhs>%MotorcycleMode</lhs>
<op>2</op>
<rhs>1</rhs>
</Condition>
</ConditionList>
</State>
</Profile>
<Profile sr=”prof9″ ve=”2″>
<cdate>1682927124196</cdate>
<edate>1683376255805</edate>
<flags>10</flags>
<id>9</id>
<mid0>5</mid0>
<nme>Toggle MotorcycleMode</nme>
<Event sr=”con0″ ve=”2″>
<cname>NFC Tag</cname>
2076
<pri>0</pri>
<Str sr=”arg0″ ve=”3″/>
<Str sr=”arg1″ ve=”3″>Tasker MotorcycleMode</Str>
</Event>
</Profile>
<Project sr=”proj0″ ve=”2″>
<cdate>1669285389683</cdate>
<mdate>1683387810970</mdate>
<name>MotorcycleMode</name>
<pids>6,9</pids>
<tids>3,4,5</tids>
<cls>com.thorkracing.dmd2launcher.Main</cls>
<pkg>com.thorkracing.dmd2launcher</pkg>
</Img>
</Project>
<Task sr=”task3″>
<cdate>1669285853745</cdate>
<edate>1683387506826</edate>
<id>3</id>
<nme>Set DMD2 Launcher</nme>
<pri>6</pri>
<stayawake>true</stayawake>
<Action sr=”act0″ ve=”7″>
1130446693
<Bundle sr=”arg0″>
<Vals sr=”val”>
<com.twofortyfouram.locale.intent.extra.BLURB>Launcher: DMD2</com.twofortyfouram.locale.intent.extra.BLURB>
<com.twofortyfouram.locale.intent.extra.BLURB-type>java.lang.String</com.twofortyfouram.locale.intent.extra.BLURB-type>
<net.dinglisch.android.tasker.JSON_ENCODED_KEYS>parameters</net.dinglisch.android.tasker.JSON_ENCODED_KEYS>
<net.dinglisch.android.tasker.JSON_ENCODED_KEYS-type>java.lang.String</net.dinglisch.android.tasker.JSON_ENCODED_KEYS-type>
<net.dinglisch.android.tasker.RELEVANT_VARIABLES><StringArray sr=””><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES0>%err
Error Code
Only available if you select &lt;b&gt;Continue Task After Error&lt;/b&gt; and the action ends in error</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES0><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES1>%errmsg
Error Message
Only available if you select &lt;b&gt;Continue Task After Error&lt;/b&gt; and the action ends in error</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES1></StringArray></net.dinglisch.android.tasker.RELEVANT_VARIABLES>
<net.dinglisch.android.tasker.RELEVANT_VARIABLES-type>[Ljava.lang.String;</net.dinglisch.android.tasker.RELEVANT_VARIABLES-type>
<net.dinglisch.android.tasker.extras.VARIABLE_REPLACE_KEYS>parameters plugininstanceid plugintypeid </net.dinglisch.android.tasker.extras.VARIABLE_REPLACE_KEYS>
<net.dinglisch.android.tasker.extras.VARIABLE_REPLACE_KEYS-type>java.lang.String</net.dinglisch.android.tasker.extras.VARIABLE_REPLACE_KEYS-type>
<net.dinglisch.android.tasker.subbundled>true</net.dinglisch.android.tasker.subbundled>
<net.dinglisch.android.tasker.subbundled-type>java.lang.Boolean</net.dinglisch.android.tasker.subbundled-type>
<parameters>{“launcherOnlySendCommand”:false,”launcherSelect”:”DMD2″,”launcherSetCommand”:false,”generatedValues”:{}}</parameters>
<parameters-type>java.lang.String</parameters-type>
<plugininstanceid>31e72a2c-86a0-4b44-84dd-4a2ca864e134</plugininstanceid>
<plugininstanceid-type>java.lang.String</plugininstanceid-type>
<plugintypeid>com.joaomgcd.autotools.intent.IntentLauncher</plugintypeid>
<plugintypeid-type>java.lang.String</plugintypeid-type>
</Vals>
</Bundle>
<Str sr=”arg1″ ve=”3″>com.joaomgcd.autotools</Str>
<Str sr=”arg2″ ve=”3″>com.joaomgcd.autotools.activity.ActivityConfigLauncher</Str>
<Int sr=”arg3″ val=”60″/>
<Int sr=”arg4″ val=”1″/>
</Action>
<Action sr=”act1″ ve=”7″>
431
<Bundle sr=”arg0″>
<Vals sr=”val”>
<net.dinglisch.android.tasker.RELEVANT_VARIABLES><StringArray sr=””><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES0>%as_running_services_after()
Running Services After
The services that are running after the action was ran.</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES0><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES1>%as_running_services_after_app_names()
Running Services After (App Names)
</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES1><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES2>%as_running_services_after_service_names()
Running Services After (Service Names)
</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES2><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES3>%as_running_services_before()
Running Services Before
The services that were running before the action was ran.</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES3><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES4>%as_running_services_before_app_names()
Running Services Before (App Names)
</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES4><_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES5>%as_running_services_before_service_names()
Running Services Before (Service Names)
</_array_net.dinglisch.android.tasker.RELEVANT_VARIABLES5></StringArray></net.dinglisch.android.tasker.RELEVANT_VARIABLES>
</Vals>
</Bundle>
<Int sr=”arg1″ val=”0″/>
<Str sr=”arg2″ ve=”3″>com.carpe_iter.cicontrolapp/com.carpe_iter.cicontrolapp.MyAccessibilityService</Str>
<Str sr=”arg3″ ve=”3″/>
</Action>
<Action sr=”act10″ ve=”7″>
20
<se>false</se>
<App sr=”arg0″>
<appClass>it.alpinestarts.app.SplashActivity</appClass>
<appPkg>com.alpinestars.techairapp</appPkg>
</App>
<Str sr=”arg1″ ve=”3″/>
<Int sr=”arg2″ val=”0″/>
<Int sr=”arg3″ val=”0″/>
</Action>
<Action sr=”act11″ ve=”7″>
25
<Int sr=”arg0″ val=”0″/>
</Action>
<Action sr=”act2″ ve=”7″>
822
<Int sr=”arg0″ val=”1″/>
</Action>
<Action sr=”act3″ ve=”7″>
808
<on>false</on>
</Action>
<Action sr=”act4″ ve=”7″>
810
<Int sr=”arg0″ val=”255″/>
<Int sr=”arg2″ val=”1″/>
</Action>
<Action sr=”act5″ ve=”7″>
20
<se>false</se>
<App sr=”arg0″>
<appClass>com.calimoto.calimoto.ActivityStartScreen</appClass>
<appPkg>com.calimoto.calimoto</appPkg>
</App>
</Action>
<Action sr=”act6″ ve=”7″>
30
<Int sr=”arg1″ val=”5″/>
<Int sr=”arg4″ val=”0″/>
</Action>
<Action sr=”act7″ ve=”7″>
20
<se>false</se>
<App sr=”arg0″>
<appClass>com.spotify.music.MainActivity</appClass>
<appPkg>com.spotify.music</appPkg>
</App>
</Action>
<Action sr=”act8″ ve=”7″>
30
</Action>
<Action sr=”act9″ ve=”7″>
20
<se>false</se>
<App sr=”arg0″>
<appClass>com.cardo.smartset.mvp.splash.SplashActivity</appClass>
<appPkg>com.cardo.smartset</appPkg>
</App>
</Action>
</Task>
<Task sr=”task4″>
<cdate>1669286839077</cdate>
<edate>1683386875238</edate>
<id>4</id>
<nme>Set Default Launcher</nme>
<pri>100</pri>
<rty>1</rty>
1130446693
<Bundle sr=”arg0″>
<Vals sr=”val”>
<com.twofortyfouram.locale.intent.extra.BLURB>Launcher: Nova Launcher</com.twofortyfouram.locale.intent.extra.BLURB>
Error Code
Error Message
<parameters>{“launcherOnlySendCommand”:false,”launcherSelect”:”Nova Launcher”,”launcherSetCommand”:false,”generatedValues”:{}}</parameters>
<plugininstanceid>0d94d164-d9cb-445a-9cf0-5fe9dc756d6e</plugininstanceid>
</Vals>
</Bundle>
</Action>
431
<Bundle sr=”arg0″>
<Vals sr=”val”>
</Vals>
</Bundle>
<Int sr=”arg1″ val=”1″/>
</Action>
25
</Action>
</Task>
<Task sr=”task5″>
<cdate>1670662468223</cdate>
<edate>1683386890142</edate>
<id>5</id>
<pri>6</pri>
37
<op>1</op>
<rhs>1</rhs>
</Condition>
</ConditionList>
</Action>
547
<Str sr=”arg0″ ve=”3″>%MotorcycleMode</Str>
<Str sr=”arg1″ ve=”3″>1</Str>
<Int sr=”arg5″ val=”3″/>
<Int sr=”arg6″ val=”1″/>
</Action>
43
</Action>
549
</Action>
38
</Action>
</Task>
</TaskerData>
