6 February 2023 at 4:49 pm
#1088
Version 2.83 (06/02/2023)
– Fixed an incorrect behaviour for controller which would make it stay “attached” to map
– Prevent Heading / Cap from moving when you stop
– Changed external widget “change widget” icon to a more “edit” style icon
– Fixed a endless loop into Notification Permission dialog
– Improved Map Theme change code
– Fixed Fuel Sensor reset on tap in OBDView (when you use calculated fuel level)
– Minor map theme improvements
