  • #37162
    Valery De Smedt
    There is a widget in to top right part of the map showing the current progress using a progrress bar, the remaining distance and approximative time of arival.  Can you add the distance from the begining of the track ?  When planning my trips, I create a main track per day and optional tracks which I will follow or not depending on the mood or weather or ….  I also create a roadbook (basically a pdf that I display in the roadbook section or simply print) which gives details on each options. I list options related to the begining of the track so it would be nice to know where I am reletive to that (ex : “Km 160 : Possible shortcut via D205, follow track D2O5 (Day 2 option 5).
    Thanks for all the good work so far !
    V/
