  • #37160
    N
    Hey all,
    I have the app downloaded recently and need a steep learning curve because I am in a little bit of a time constraint.
    When I am in the nav mode and click on the had stations button there is a list of gas stations and its distances. But is there a feature to see the gas stations on the map all together?
    #37161
    TR42
    To make all gas stations on the map appear, as with any other type of POI, when on the map screen, tap the Layers icon at the top, then in the list to the left tap POI Icon Highlight. Then in the POI list on the right, choose the type POI icons you want to always show on the map.
    Hope that’s what you were looking for.
    #37171
    N
    @tr42 Thanks for the reply. This is helpfull. Now I see the POI on a certain zoom level. I would like to see these POI on a larger zoom level as well. Is this possible?
    #37172
    Guzzist
    No – only in detail level
    #37179
    On most EU countries, if you do that you will not have a map, instead you will have it fully filled with GAS Station icons.
    Plus the map will become so slow you will barely be able to use it.
    We will see what we can do to improve it a bit or maybe even move to cluster icons (grouped)
    TR42
    Or maybe restrict icons on screen to a prescribed radius around your current position. Tho, that’s probably harder to code for than grouping them.
    #37190
    TR42
    On the map screen, tap the GPX icon. Then tap the gear settings icon. Then, In the right column, toggle the “Hide Waypoints on Low Zoom” on and off. Try both settings to see which you prefer most.
    Like Joao stated, when you zoom out, for POIs like Gas Stations, in which there are usually a ton of, the screen becomes filled with them to the point that you can’t see what you were wanting to see by zooming out in the first place.
    For that reason, you might skip enabling Gas Station icons until you need to start looking for a gas station.
