  • #36978
    Chloé
    Hello everyone,
    I recently bought a T-865X and I was suprised not to find the recordings I did while riding.
    After a lot a fiddling, I figured that the generated GPX files where only found via the “Files app” at Android\data\com/thorkracing.dmd2launcher\files\User\GPX\Recordings
    But from the GPX tab on the Maps page, “loading a file” can only acces Android\media. So, in order to get access to the generated tracks, I need to move them via “Files app” to another location (like Downloads or Google Drive).
    I would be nice to have the option to choose where to save the recorded GPX, or to find them in the Recorder tab or with the loaded GPX files that we already have (Android\data\com/thorkracing.dmd2launcher\files\User\GPX\Imported)
    Thank you in advance and good luck with the current power outlet you guys are maybe experiencied (directly or indirectly)
    #36989
    TR42
    Joao has commented on this recently. I think any route/track you record on the fly while you’re riding, after being saved, is supposed to be found by tapping the GPX icon at the top of the map screen, then tap Recorder, then tap Recordings. The gpx files you’ve recorded with the tablet are supposed to be there.
    #37033
    Tap GPX round button in the map view, Tap “Recorder” in the bottom, Tap “Recordings” in the bottom.
    If you want to export the file you can tap on “Share”, usually i send whatever file i want to Google Drive so i can access it anywhere.
