  • #34142
    Alwyn Burger
    I just fitted my new DMD2-x attached to the DMD 12mm AMPS Bracket Long SE.
    The tab’s weight pulls it down despite it being as tight as the screws can go and the faces are completely closed.
    Are there any tips and tricks to stop it turning on the support bar and stay up?
    #34148
    sonwon
    Maybe 1mm thick rubber pads on the clamp section would work, not sure though?
    #34156
    Ruud Enroute
    Hi Alwyn,
    also the short version has the same problem.
    Before the clamp can be tightened, the gap is completely closed.
    I used the angle grinder to remove about 1mm from the clamp.
    Now, fully tightened there`s a gap appr. 0.5 mil. And the DMD2 865X does not move, even after a road paved with cobblestones.
    I made a notification to Thork via my dealer in the Netherlands.
    Hopefully this will work for your long version too.
    Ruud
    #34168
    Alwyn Burger
    Hi Ruud
    Wonderful thank you. I’ll do that next weekend. Having a full on rainy week here in Tuscany (Italy).
    #34456
    Gonzalo Olivera
    If the gap is not too big, I will try applying some nail polish in the clamp (in the inside part in contact with the 12mm bar). Apply some transparent or black polish on that area and let it dry well. This is probably the easier and cheaper way to solve the problem.
