31 August 2024 at 11:40 am
#9409
It works fine with my Suzuki V-Strom DL650 2023. I’m sure it will work fine with any third-gen model from 2017 onward.
Fuel level and Mass Air Flow are not working. I think these are not properly reported by the ecu.
The throttle position starts from 21% but this value is coming from the ecu directly. So, I just use “Calibrate Throttle Position” from the settings and it works fine.
Tested with OBD Scanner M1 DMD2 and ELM327 mini.
