#7613
DMD2 3.00080 released:
– GPX Manager – now supports GPX files with ROUTES.
– GPX Manager – Removed Advanced button and replaced it with “invert direction” switch
– GPX Manager – Preserves last selection position going forward and back in the menus
– GPX Manager – Removed all options to convert Track to calculated route -> Finally!!! Bye bye!
– Map Themes – Made some small islands name show only on lower zoom levels and made some places like “neighbourhood” and “hamlet” show at higher zoom levels
– Moved from Location Manager provider to Fused Location Provider – Falls back to Location Manager when Fused not available
– Fixed a case where voice would trigger for “Wrong direction” and “Away from track” even when it was disabled
– Map View – When you hide the right side widgets, if you have active track instructions they will take its space
– Navigation and GPX Progress – fixed a case where they could freeze
– Added extra controller key debounce check to check and prevent stuck keys
– Many other small fixed and improvements, this was a big update, will keep it under the radar to do immediate patches in cases anyone finds any issue!
Sorry for my recent absence, two weeks being hammered by COVID.
