4 July 2024 at 2:37 pm
#7565
At the moment you have to choose at least 2 data fields in the roadbook. You can leave the third filed empty. But sadly the empty space is not used to increase the font size. Please have a look at how you have solved this issue before the big update. There it was possible to use fewer fields and therefore have a bigger font. Thanks a lot.
When you have less fields the space you would gain would be vertical. To increase font size you need both Width and Height…
