Hello Joao,
I would like to use the roadbook function of DMD2. (Testversion 3.00067) To enter a correction factor I use the distance multiplier.I enter 1.03 instead of 1.
But I also need to set the scroll amount for the paper run movement.(i set it at29)
But even though I always press save the distance multiplier setting always jumps to 1
and the value always changes to nearly zero when scrolling(there is no movement when i press the button of th CI Terrain ComandIII )
What should i do?
Thanks for Help
Johann Strasser
to find in:
Adjustments (in Roadbook mode)
Distance multiplier:
In case an adjustment to the roadbook distance is needed, add a correction factor for the total and partial routes
