30 May 2024 at 12:51 am
#6391
PCFly, I have the exact same issue. I have a Husqvarna FE 501 S, purchased the OBD2 cable from Thork Racing (US version), use the OBDLink MX+. I also get a blue indication and also get a voltage reading of 14.2v. Were you able to find a resolution? Oh, I should add that I run an Athena GET ECU…do you also run that aftermarket ECU?
