#5573
There are two ways of using an SD Card:
– Formatted as extended internal memory – dangerous as it can easily damage your OS
– Formatted as removable external storage – safer but not all apps can use it
Im not sure if the apps you mention can use the SD Card as removable storage, since Google changed the way apps can access it. If those apps did not yet implemented the new external storage access API then you will not be able to use the SD Card for them.
DMD2 app on the T865 can write to SD Card when you format it to external storage, that is a safe option that should work.
