#4464
Ali Endureur
Hello Remote Controllers should be back working. As for the old CI and Roadbook im afraid the old CI will never work that good on DMD, i will try to improve it and also check the BarButtons thing. It is a nightmare to support all these freaking controllers…
I’m really sorry about that – but you don’t want to buy new hardware after every release. Especially as the button function works in all other apps. So not only in the DMD2 main menu & the map menu, but also in other apps. The error only occurs in the DMD2 Roadbook app.
Incidentally, I recently started using a DMD-T-865, before that I had a Carpe Iter V4b – still with the officially licenced DMD2 software. Everything ran very satisfactorily on it. So it would be really great if the bar button functions of the CI controller could be implemented again. I change motorbike frequently and the ingenious thing about the CI controller is that it doesn’t need a power supply as it has an internal battery.
Your work and efforts are great though!
  • This reply was modified 8 months ago by Ali Endureur. Reason: important additions
