For me, the DMD Hub app is a no-go, as it uses Google Play and I cannot run the app with the Play services check. I’ve done a TON of research and tests for the other app I’m using, and I have the other app working perfectly, but it required me to remove Samsung’s phone app and install a different app, see my notes on your discord channel for more info on it.
Its unfortunate, but whatever Samsung, and from my research, several other brands too, installs into their phone app to block any push notifications via BT is the issue with both apps not working as intended. If you’re able to dissect their app and determine what line of code does this push notification block, and you can find a way around it, that would make the app absolutely perfect. Other than the phone push notification (which to me is the most important notice I think most of us need to pass to the second device), the other apps work great, including texts!
