#36611
I’m back again DMD support…… I swapped the Athena with an OEM flashed ECU. I had high hopes, plugged everything together and well…..nothing. 🙁 It WORKS!! DMD, I’m very happy to report……it all finally WORKS!! Thank you for dealing with my drama and frustration. Solution is a reflashed ECU (not a GET/Athena). I’m still putting much of the bike back together as I’m adding a larger tank and swapping fairings. I’ll report back with some miles down the trail. Fingers crossed, thanks again DMD and ADV-Tim for your help. 🙂
As i keep saying, there is not much to it, the only thing the ECU needs is to output OBD2 data type, if it does it will work, always.
