2 April 2025 at 2:11 pm
#35676
Hi Arian,
I know from other apps, some navigation mistakes will occure, if you start after the first route point. Then those app will route you always back to the not reached route point. Therefore it would be good practice, to set the first waypoint in a little distance to your home.
But with DMD2 app, I believe navigation will simply start if you have reached the first route point. I made the test:
- setting the first route point in a distance at my home -> navigation doesn’t start
- setting the first route pont directly at my home -> navigation starts immediately
If the first routing point isn’t close to your home, or you have received a foreign gpx – you can long tap on the first route point and can select in upcomming dialog: “navigate”. This will navigate you from your current location to this routepoint.
