Creating Straight Lines Between Waypoints in DMD (Support from Thork Racing)
If you want to connect waypoints using straight lines instead of routing along roads or tracks, follow these steps:
Load your GPX file with waypoints into the DMD app.
Open the GPX Manager and select your GPX file from the list.
On the right side, you’ll see the waypoints – click there and arrange them in your desired order.
Go back and select point “Convert.”
The app will prompt you to either convert the waypoints to a line (straight connections) or a route (following roads/trails).
In your case, choose “Lines” to display a straight path directly between waypoints — ideal for off-road or desert navigation like dune crossings.
DMD - Top Navigations and Motorcycle Accessories from Portugal - MotoNavAdventure, your Swiss Reseller
