#34804
Robert
You’re correct, there is no Center option when configuring the functions in DMD maps.
do you have an email ??
front joystick: up is F4, down is F3, right is F2, left is F1
side joystick: up is F5, down is F6, right is F7, left is F8
So i have, relative to above
front joystick: pan up, pan down, pan right, pan left
side joystick: F5 nothing, F6 nothing, F8 zoom out, F7 zoom in.
I’m running android 14, latest update.   Button app version 1.48
To be clear i have the 865x but that should not make a difference  I power both independently and use Bluetooth
with Bluetooth, how many devices do you have paired ?  Need to keep it to a minimum, say no more than 5.
This H1 I also see, but I think it should not make a difference    During the test you will see a number that corresponds to the movement, that when configuring in DMD, and the F(n) movement (as above) gives you the movement function you want
Do all the joystick movements work in Button tests ??
