#34800
chico
Thank you Robert for your in-depth help.
I did some experimenting with the buttons app today. On F1 , the panning joystick works. The other joystick is like I mentioned before acting as the H1 buttons. So Button 1, 2 and 3 on testing.
Now, 3 functions should be needed, Zoom In, Zoom Out, and Center. In the buttons app, the Zoom functions are programmable and it does work now. Moving forward as Zoom In, and moving backwards Zoom Out.
The Center function is nowhere to be found. It would be so great to have the Center function on moving upward.
That leaves downward (long hold) for switching between Function 1 and Function 2. The momentarily downward could be used for some other function.
Questions:
What setup do you use in the buttons app, and what functions did you program on which movement?
Have you found a Center function?
Or are you using an alternative app? If yes, which one?
Also in the bluetooth connection, I do get regular pairing questions while driving. Switching bluetooth off, the T865 keeps the C1 as H1 in memory, until you switch it off, then the pairing process must be started again. Quite cumbersome for a so called “Plug and Play”.
I hope that the DMD folks can write a software solution OR the SilverFox makers come up with a working C1 !
Thanks for your time, highly appreciated…
