#34652
last week I recieved my tablet, mounting hardware and controller. I installed everything but I can hardly use the device, usually I get a blank map after the device boots from shutdown. And what ever I try, it will stay blank. I can see .gpx tracks, i can click on the map and it will navigate there. It feels like it just does not render the visual part of the map, but i can read were i want it to go to. It calculated to route to a .gpx track for instance. I have to delete and then re download my country (the netherlands) for it to work. I am very very disappointed about the device at the moment. At almost 1400 euros and it does not work without faffing around with settings and reloading maps. What am i doing wrong? Alex
Are you using an SD Card?
Did you only download Netherlands?
You do not need to touch any setting, just download the map, done.
