#34443
DavidE
Same issue
T865x tablet
DMD2 version 3.00178
528G SD card
card was “formatted” by installing in tablet
card storage was working fine, then all of a sudden something is corrupted. Just turned tablet on and it had the problem.
i have tried switching storage from removable SD card on/off with blue toggle.
tried power cycling in between selection changes.
i have an overlay oval top of screen DL:20 Acitve
I have different versions of this problem….
sometimes the maps just spin like trying to load
sometimes they just say in Que…
right now I have it set to set storage to removable SD card
it still says DL: 20 Active in bubble overlay at top of screen.
in maps section
Map Configuration
Base Map Source
message says no downloaded maps yet, click download maps to download
select download maps
region USA
SELECT  Nebraska, Kansas and Oklahoma
download
get message Not enough storage space
turn off set storage to removable SD card
select yes to move map files to internal storage
nothing changes
still have DL: 20 Active
select same maps Nebraska, Kansas and Oklahoma
changes to in queue with spinning circle
30 min later no change
did this tablet completely crash?
I’m unable to resolve issue… what is the fix?
message edit / update
I’ve been trying to fix for about 7 hours now and no change.
just checked an hour later, map is still spinning with in queue message and not loading.
no maps loaded, no maps will load
has anyone resolved this issue?
  • This reply was modified 1 month, 2 weeks ago by DavidE.
