7 March 2025 at 6:41 pm
#34105
I believe it’s not a blanc/white screen. If I zoom OUT – I can see, the map is focussed at middle of Atlantik between America and Africa. Then I pan the map and zoom in, to focus to my home base. There I can see the map from Germany again – everything is ok
That you have to zoom out to be able to see the map, then zoom into your location, every time you turn on the unit, IS NOT OK. The tablet should not do that. I say that because every other GPS app I’ve ever used doesn’t require you to do that. My new tablet is doing the same thing, firmware ver. 3.00176.
Until I read this post, I couldn’t figure out what was going on. The GPS accuracy at the top of the screen was showing a figure, so I knew the unit had my location.
This reply was modified 2 weeks ago by
TR42.
