Quick update for those who encounter the same problem later on.
I received the following guidance from Thork racing:
“Unfortunately, the latest OS update encountered an issue that prevented it from being properly applied on some devices. As a result, a small number of units are unable to boot correctly.
At the moment, the only solution is to wait for the device to display the “Android Recovery” menu after a few reboots. When this happens, you’ll see two options: “Try again” or “Factory data reset.”
To navigate the menu, use the volume up/down buttons to highlight “Factory data reset,” then press the power button once to confirm. Please note that this will erase all data stored on the device, but the microSD card will remain unaffected.
After this the device will boot normally but it will be as if you were starting it for the first time.”
So with this solution you’ll unfortunately loose all your settings, but not the DMD2 app (phone will reboot to factory settings).
Hope this helps!
