#28902
Thomas Heisterhagen
Okay, I did it exactly as shown in the YouTube video.
Result, I was able to download all the maps. Result two, now new problem. The map is displayed and I am supposed to have a GPS signal that is displayed at 4.7. When I try to navigate, it keeps saying no GPS signal found.
With Garmin navigation, I can sit in a closed room and it works. It may be that everything works on your Overland, everything worked for me before your update, but now nothing works at all. And it’s not just this complete ignorance of what you actually publish, but that one update is followed by the next with new functions. You should first make sure that the things that are there work properly and not keep releasing stuff that leads to problems. But that’s my opinion and people may like to try out new functions all the time. I would like people to know in advance what’s coming and then be able to decide whether they want it or not. This way you are forced to install something because you don’t know whether this update will finally fix the bugs that keep cropping up.
And one more thing that always strikes me: If the Garmin system is so bad in your opinion, why do you offer a version for this? I paid more than 100 EUR for your license and what I get is a bunch of half-baked software that sometimes works and then doesn’t after an update. So if all this is down to Garmin, why exactly do they manage to sell a system where the things that are promised actually work? It’s easy to always blame others and not realize that your development process needs improvement.
How likely is it that a system that previously worked without any problems will no longer work after an update and that the fault is then to be found in the hardware?
