#28882
Thank you for the tip and I have followed it. As a result, however, I can only report that everything will be deleted, both settings and map data. The whole thing would be bearable if the map download worked. But this is exactly what it does not do. I have now spent three hours trying to download maps, with the result that 100% is always displayed, but no download works. The symbol remains that no data is being downloaded. So if it is true that it is due to Android, why does the SD card work with the Garmin? No problem under the Garmin and everything worked before the big new update. It simply cannot be true. I’m now really annoyed at how one update after another is pushed out here without it being clear what it’s all about. Why are there no release notes etc.? What is being delivered here is really garbage. I urgently recommend picking up a Garmin Tread Overland and testing it.
Got a Garmin Tread on my desk, works perfectly, including downloading maps.
Just downloaded one, no issue, if DMD2 cannot download maps then its a storage issue, either no access to storage or SD Card related issues. For the first a simple DMD2 Clear App Storage sorts it.
In the last 6 months, there has been no change to the code related to downloading maps, zero, none.
The fact the SD Card works with the Garmin does not invalidate that its garbage, its slow, its a mess to deal, vibration can easily disconnect it or cause data corruption.
If the issue is storage permission issues, as i said, do this, and NOT uninstall and install again:
Make sure after clear app storage that you also delete the DMD2 folder in the Garmin Tread SD Card if you intend to use it.
