#28841
Okay the last update helps a lot, but now it’s impossible to navigate with DMD2. After a search like Gas Station, the navigation stops with a failure message. calculate error java.io.FileNotFoundException: /storage/2009-172E/Android/data/com.thorkracing.dmd2launcher/files/Router/Calculated/directions0.gpx:open files: ROFS (Read-only file system) I think I need help to solve the problem. Thanks Thomas
Not related to the app, this means that DMD2 no longer has access to that storage location.
Either SD Card permission gone, SD Card removed, or any other of the 10000 reasons why SD Cards suck in Android.
To fix storage permission you can always do an app reset: https://www.drivemodedashboard.com/support/faqs/?Display_FAQ=9012
