Hi Pcfly,
Thank you for your reply. I also had the problem with the white screen. However, the solution was that the map assumed I was somewhere in the Arctic because the GPS wasn’t working. After the second update it worked. Currently I only have the problem that any navigation crashes with the described error. As much as I like using the DMD2, this forum is actually pointless. No matter how often and what I write about, I don’t get a single hint from support. DMD2 support is actually non-existent. What bothers me personally, but maybe I just don’t know where to find it, are the release notes. I install some update and then have to search around to find out what has changed, plus the constant features that don’t work. For example, the ability to create profiles. When I try this, DMD2 always crashes. Testing is done at the customer’s premises, as always.
