26 September 2024 at 10:19 am
#12425
Use the first top left button in the map view, disable the follow location (empty arrow).
Even better, if you want to quick view stuff on the map use the small “minimise” button in the top right corner of any dialog 😉
If you want to close the dialog and the map not move on closing then you should disable the follow location first:
